Raymarine radio
Seastoke
20 Sep 2011
Ok like most old above radio , the handset wire has fell in bits , I have done a repair with shrink sleeve all good ,but I still struggle with the sound on the flybridge.it’s an old system on sea talk .
Now I only steer from the fly, so I am thinking of retro fitting a freestanding unit with built in speaker and it’s own aril does this sound feasible . Thanks for replies.SS
jfm
Jersey/Antibes
It all comes down to wiring runs or conduits. If you can (i) run 12v from a spare circuit on distribution board on the deck below, (ii) run NMEA GPS information to the new radio from nearby nav gear, and (iii) run coax to wherever the antenna will go, then it's 100% feasible. Otherwise you have some challenges to work around.
Seastoke
20 Sep 2011
Thanks for reply what is the nmea for ,to the radio ,sorry don’t understand
stelican
25 Nov 2004
fareham hampshire
Old school use to be take power supply direct from battery. But I doubt if any do now.
It may be worth trying a waterproof car audio speaker in place of current speaker.
[165042]
25 Nov 2016
NMEA is used to get GPS information to and/or from the VHF for DSC. If you have an old Seatalk system it's likely Seatalk is providing the GPS (if at all). I would replace it with an Icom 423GE or similar which has it's own GPS antenna.
petem
Cotswolds / Altea
www.fairlineownersclub.com
What make and model is the old radio?
Seastoke
20 Sep 2011
Hi , I don’t think you can replace a raymarine with a standard speaker.
Fire99
11 Oct 2001
Bangor NI
I have a Raymarine 230e 2 station kit kicking around somewhere with one of raymarine's active speakers and the 'black box'. One handset is faulty, the other is fine. Both I fitted new flex to the handsets. Not sure if any of that gear is of use or not..
Seastoke
20 Sep 2011
I don’t think the 230 will work
jon and michie
28 Dec 2014
I have a Raymarine 215 and have a virtually brand new cable on the mike - if thats any good to you ? its an easy install just plug in at both ends
