youen
Can you swap a Raymarine paddle wheel speed sensor for an ultrasonic sensor in a Seatalk system st 60?
I believe the Airmar number is CS4500. I considered this option, but way too expensive. I've finally started work on my YAPP-like box to simulate the paddle wheel from the GPS signal.
I'm confused as to why you would devise such a system.
I'm guessing that it's because certain Raymarine kit requires a speed input but will only accept it from the STTW sensor, not GPS SOG. I think that includes the wind sensor.
I'm a recent convert to speed through the water data, it helps with much more than I thought it would. Surprised how slowly the paddle furred up.
I don't have a paddle wheel and I can't seem to get my Raymarine kit to display log information i.e. distance travelled, from the GPS signal.
Is there a way of doing this? Could be I am doing something wrong!
Richard
Because it isn't designed to do such a thing. If the GPS fails, most people would say that the key issue for navigation is how far you've travelled through the water and that's why you need a paddle wheel or one of those very expensive doppler units that works without a paddle wheel...
I think that we should always rejoice at every sinner who repents. You're right.I'm a recent convert to speed through the water data, it helps with much more than I thought it would. Surprised how slowly the paddle furred up.
Richard
The current range of plotters keep a log of distance travelled as recorded by the GPS, unfortunately mine appears to have got a little confused during a software update and it telling me I have travelled some 5,000 miles this season![]()
Do you need to buy an interface box to link the Airmar ultrasonic sensor to the Seatalk or you can plug the sensor directly the same way as the paddle wheel?And at end is the Ultrasonic efficient and reliable?Thanks
