wiggy
My course computer says
"3.6Grounding
These grounding requirements are applicable for Raymarine equipment with a dedicated ground terminal.
• The ground terminal must be connected to a common ground point.
• It is recommended that the common ground point is a bonded ground,i.e.with the ground point connected to battery negative, and situated as close as possible to the battery negative terminal. If a bonded ground system is not possible ,anon-bonded RF ground may be used."
What does this mean? Mine was connected to the saildrive leg of my MD 2020, this worries me as Volvo state that nothing should link the leg to earth.
I'm confused. Where do I connect this, at the moment it's connected to nothing.
"3.6Grounding
