superheat6k
I am feeding NMEA0183 data stream from my new Plotter to a C80 MFD, and the external info on the C80 shows sentences and bytes are being received, but the MFD is not using the data provided to display position nor AIS.
The same set up worked just fine on my last boat with an identical set up with the NMEA0183 providing the C120 in that case with both GPS positional and AIS data.
I have set the baud rate to AIS 38400, and have changed loads of other settings.
I also did a full reset and now the boat thinks its just off the entrance to Miami harbour !
The GPS source is accurately sending the true boat's position.
The C80 has two inputs for NMEA data in - AIS in and NMEA in. I have tried both separately, so should I try both on the same external feed connection ?
