Roger_D
you might be interested in this exchange...to be fair it was quick. Start at the bottom.
Discussion Thread
Response (Chris Martin) 08/03/2007 11:09 AM
The ST 40 is the oldest here, been around since 2001. The ST 60 Plus units came out in 2006. We try and upgrade the series every 5 to 7 years.
Customer (Roger Jan) 08/03/2007 11:00 AM
Of the ST40s and ST60+s, which the most recent and which is most likely to be discontinued first.
Thanks again
Response (Chris Martin) 08/03/2007 10:56 AM
Yes it is, the ST 40 can also be used but has the same wiring issues as the ST 60s.
Customer (Roger Jan) 08/03/2007 10:52 AM
Ok, is the ST60 plus compatible with the ST50s. Are any other Raymarine products compatible,ie the ST 40s i need to replace the speed head and need advice on what to replace it with, ie the most future proof. Thanks
Response (Chris Martin) 08/03/2007 10:41 AM
Yes, the ST60 will talk to the ST 50 but you will have to cut off the ST 50 SeaTalk connectors and replace them with the small spade connectors that the ST 60 use.
Well actually the ST 60 have been discontinued, They have been replaced with he ST 60 PLUS.
Customer (Roger Jan) 08/03/2007 10:28 AM
The st50 speed head is one of 7 st50 instruments I have all connected ie depth, wind, compass, st 7000 and multi repeaters etc. What can I replace the speed head with? Would ST60s be compatible with the other instruments..would they connect, or can you advise what else I can do. Will you be discontinuing the ST60s as well,if so when.Thanks
Response (Chris Martin) 08/03/2007 10:09 AM
There is a memory chip in the unit that may have gone out. Unfortunately, we can no longer service, repair, or provide parts for the ST 50 line of instruments.
Customer (Roger Jan) 08/03/2007 05:37 AM
My ST50 speed resets to 0 each time I power up. Does the instrument have a small lithium battery to retain the log reading. Is so, can this be replaced? Thanks
Discussion Thread
Thanks again
