valeria
New Member
Hi,
I have currently (almost) repaired and serviced a faulty AutoHelm 1000.
My Question....
I am left now with one problem. I think the unit is too much sensitive now. At a slight movement, the shaft travels almost full length. I am assuming that with a few degrees, the distance travelled by the shaft should be proportional. Can someone confirms this please?
Anybody knows if someone has a copy of the circuit diagram. It would really help me out.
Useful Info
My initial problem was the arm extends in 1 direction only and some other dodgy behaviour. To cut it simple, I had to dismantle the compass unit, to find the two red LEDs not working due to common resistor failure.
I have uploaded a small video clip as many have asked about the mystery inside the compass unit (not a flux gate). This clip gathers some relevant images found on the net and added my contribution to it.
http://www.youtube.com/watch?v=My1mgTBlX1U
I have now a good compass unit. Had also to replace IC LM324 as one of its 4 internal op-amp was duff and soldered all output transistors due to visible dry joints. Now everythings seems working :4v rest position, 3.7v and below starts retracting, above 4.3v starts extending.
Hope I have helped someone too
My Question....
Useful Info
