Birdseye
My boat has ST60 but the masthead unit on the early ST60 was carried over from the ST50 so has a cylindrical body. Mine has stopped working electronically with suspect Hall effect sensors. To replace with the Raymarine unit now available is £370 before adding the cable and block , and even then the speed will over read by 30%. So really what I need is a complete wind instrument that will then be NMEA 2000 Raytalk 2 which in turn will look out of place and need some data converter which then means new plotter new radar, speed and depth plus AIS etc. You can see the cost mounting up like the rotating dials on a slot machine.
Others must have had this issue and I am certain someone will have found a way or replacing the hall effect sensors, maybe with a small elecrtonics outfit. I am willing to wield a soldering iron.
Help!
Help!
