Raymarine A9 to Axium+ 9 RV wiring issues
PNW Racer
New Member
2 Sep 2025
I am trying to replace two A9 chart plotters with Axium+ 9 RV units. Cabling issues.
Replacing the power cable no problem.
Both the A9s had two network cables attached, only one plug on each Axium. What do I do with the extra plugs?
Each A9 had one Seatalk NG cable plugged in (white/black). Using the adapter cable supplied with the Axium (only 6" long) it will accept a Seatalk NG cable. The problem is they are both female.
Boat has Raymarine and Garmin devices with Seatalk and NEMA2000 backbones. See attached schematic.
Dean
Sounds like you need a network switch. I had to do that when I wanted to connect an external keypad, a camera, a radar & 2 Axiom MFD's together all on Raynet. You can pay silly money for a Raymarine one or else get a generic 12 volt one like this...
Industrial Ethernet Switches - Brainboxes
The Raymarine devices have Raynet connectors on but Raymarine do Raynet to RJ45 cables...
RayNet (Female) to RJ45 (Male) Cables | RayNet Cables | Raymarine
For your last problem is this what you need?
Raymarine SeaTalk ng Male to Devicenet Female Adapter - A06082
If not then there are longer versions of the SeatalkNG/DeviceNet cable that came with the Axiom at usual Raymarine prices. Use this longer cable instead of your existing black/white spur cable to plug into your backbone connector.
If that's still not long enough you can extend you DeviceNet cable...
Raymarine NMEA2000 Devicenet Male to Devicenet Female Cable 2m - E70260
