Whitelighter
So the boat came fitted with an early (1996) ST40 bidata.
Separate transponders and the depth has never worked.
Decided to buy new transponder and ST60 tri to replace.
Depth now works.
Speed though just shows 655knts even with the transponder disconnected.
Did a reset to factory settings and with the unit in repeater mode the speed shows ---- with nothing attached, as I would expect.
Make it back to master unit for speed and hey presto we are setting world records on the berth.
I know the speed transponder works with the ST40. I think the ST60 is ok as it works on other settings.
The speed transducer doesn't have the temp sender so only 3 wires not 5, but since the fault occours when no wires are connected I can't see that this is the cause.
Anyone able to suggest what might be up?
Depth now works.
