CaptainBob
Ran my engine today for the first time since I bought my boat. First time on my own. Quite exciting!!
Not sure if it's alright though.
I used a little jug to "prime" the cooling system with fresh water until it stopped going down the pipe (temporary longer pipe added for this purpose in place of seacock attachment), then put that pipe in a large bucket of water to act as "the sea".
Started the engine.
At first I got exhaust gases AND water out the back, but then it was just exhaust and a teeny amount of water.
I assumed I had an air lock, so re-primed the pipe... got some water through again for a bit.
I fiddled around a while like this, keeping a really close eye on the temperature guage.
Temperature guage got up to near 80C and I was about to give up and kill the engine quick sharp when I think the thermostat must have kicked in, the temperature dropped fairly rapidly, and a good flow of water started coming out with the exhaust.
After a bit the thermostat must have closed as the flow slowed again to a few drops and the level in my bucket stopped dropping... only to start flowing again when the thermostat (I assume) opened.
Guessing I've got a problem here? Can't be good to have my impeller trying to push water through, and have it not go through? Furred pipe in the system after where the thermostat is?
Or is this actually correct operation?
Additional... After I shut down the engine, I felt the cyl heads to see how hot they were to the touch. They seemed fine. Not too hot to hold my hand on for a short time.... but I was surprised to feel that the aft one was noticably hotter than the foward one... is THIS normal?
Many thanks for any insights!!
Started the engine.
