jonrarit
Ok here's the set up.
2 Year old Alternator connected through a Sterling Alternator-battery charger unit to the batteries.
9 times out of 10 fire up engine, voltage comes up to 12.9v then sixty seconds later engine revs drop as the A2B kicks in. Voltage rises to 14.4v until charged then drops to 13.9v float after 30 mins or so.
However 1 in 10 fire up engine, voltage comes up to 12.9v, A2B kicks in and after 10 mins or so the voltage starts fluctuating 14v 15V 16V ... at this point the A2B has an overvoltage alarm and disconnects the load on the alternator, voltage returns to 12.9v ....then cycle repeats continuously.
Only cure is turn off engine (which turns off the A2B too) Restart and all is fine........
The voltage sense wire (yellow) that comes out the alternator is connected to the B+ as per the Sterling instructions so as not to cause "conflicting regulation between the A2B and the alternator regulator"
As this is intermittent (only 1 in 10) and it's only started doing it this season my thoughts are with the alternator regulator but I'm open to suggestions please as over 16v in the system cannot be good
Jonathan
Jonathan
