jwilson
The original fit Sony radio/CD player on my boat was swapped some years ago for a Panasonic. Personally I almost never turn it on: if I'm sailing I like silence, and I get weather forecasts from the VHF. However there are those who like to listen to the radio, and neither radio/CD has ever had good reception.
The original fitment was a small amplified antenna mounted on a bulkhead hidden behind the chart table instument panel. Only plywood and GRP between it and sky/horizon. The newer radio seemed even worse than the Sony, so I swapped this antenna for a similar new "car windscreen mount" powered one. Only fractionally better. Have also tried a non-powered stalk type car aeriel also hidden in same area, which is actually not much different to the powered ones, and is what's there at present.
I really don't want a long cable and a hole drilled somewhere to mount an aerial on deck. Any suggestions for an effective aerial: the radio is AM/FM, not DAB. I'm currently working through a series of "niggles" on the boat equipment, and this is one.
