Radio aerial wanted
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
I want a radio aerial for my FM radio receiver, to mount of the pushpit. Any suggestions as who supplies a waterproof rail-mountable one?
Thanks.
dickh
8 Feb 2002
Suffolk
I've used one of those stumpy flexible ones sold in car spares shops - OK, bits will rust eventually, but when they fall to pieces you buy another. Being flexible doesn't matter if it gets knocked now and again.
fireball
15 Nov 2004
Any reason you need to mount it outside?
We've just purchased a cheap telescopic one and mounted in a tall locker - ok reception isn't going to be the best ever - but it is one less item outside and no thru-deck fittings either....
snowleopard
Cornwall
i shoved a yard of wire behind the headlining and stuck it into the central pin of the aerial socket. crude, but it seems to do the job.
AngusMcDoon
20 Oct 2004
At the moment I have a length of wire inside pushed into the aerial socket on the back of the radio, and reception is not good. I will try an aerial internally next. Thanks for the suggestion.
