KAM
Anyone out there have any experience with these. If so do you have any numbers such as cruising speed, revs, power boat size etc.
Ignore those that say reverse is a problem because in reverse the blades are forced open not closed.
You may want to think that one through. When the engine goes into reverse it is the blades of the prop that are trying to pull the boat through the water. The act of pulling has the effect of trying to close the blades. As you rightly say increased revs will counteract the 'closing' effect.
There's a video on youtube that shows the effect.
