cindersailor
Can anyone tell me how Radice folding props (2-blade) are fitted to the shaft. All I have been able to find out is that they fit onto a conventional taper, but where does the nut go? Are the blades removed first to fit the hub with the nut then located behind the blade gear teeth when the blades are refitted. Is a special (small diameter) nut required so that it will fit into the hub? Any info would be useful. Thanks.
