indianajonez
New Member
Hi,
I've come across a roll of radiator reflector foil 2mm x 470mm x 4m (metallised polyester and polyethylene foam) .. closed cell?
What i want to know is if I could use the above as an underlay underneath a foam backed vinyl, or carpet headliner.
I just want to give the headliner a smoother finish by putting the radiator reflector foil up first, as this should reduce the amount of visible undulations from the grp.
The radiator reflector foil is incredibly cheap at only £5.99 per roll (which is why I would like to use it), lightweight and should be very easy to place.
Might also use it on the walls, again underneath foam backed vinyl or carpet headliner.
Can anyone see a problem with this?
Thanks,
Indy
Thanks,
Indy
