donm
I fitted a Racor 500 to my Beta 20 hp last winter to avoid the mess and sealing problems with the CAV filter. All fine until yesterday when the engine faltered and then stopped due to fuel starvation. Changing the element did not help and when I blew down both the in and out pipes towards the filter they were both blocked at the filter but were clear in the other direction. I ended up taking the body off and blowing it through to clear it, and although nothing obvious came out, all is working well again.
So a couple of questions about Racor filters which someone may be able to answer
1. This is a turbine filter but my little engine does not draw enough fule to turn the turbine so is this a problem?
2. What does the check ball do, and could this have been stuck and so be the problem?
3. Have I over complicated things - but I am not going back to a CAV but could fit a spin on?
