IanR
Ok chaps here is your quiz of the week
Scenario
Bilge blower intermittently stops blowing, works at low revs but frequently cuts out, can't hear at higher revs, bit think cuts out too. obviously stopped working later too as engine bay very hot. Engine BTW is Yanmar 3GM. I first assume that brushes on the blower are worn and decide to replace. (Duh moment 1)
Action 1 replace bilge blower with one bought from Chandler 25 squids down
Nothing worked, worked way through wiring to relay and cheched OK, relay links to blower via start motor. (Duh moment 2) Went to Halfords and various trying to buy a Hella relay but could only buy flasher units so went back and tried various plans including swapping out relay and direct connecting supply 12V to blower (No Go) Eventually disconnected all parts, checked all fuses (strategically hidden in depths of engine bay) and discovered replacement blower was short circuiting and cutting out after 2 secs by overheating, boat is 12v and DC motor must have been 6V. (Duh moment 3)
Went to chandlery and tested blower they suggest it was 6v motor and a fire risk (you don't say!), I swapped out for proper 12v model, installed ok , tested ok. (Oh really - then read on!)
Then put boat back together, tie wrap all wires neatly etc.. etc.. you know the routine, blower seems to work, smug grin of satisfaction despite troubleshooting having taken almost 12 hours for a simple DC motor!
Then find bilgeblower cuts out at high revs and only starts up again intermittently at low revs, wiring for bilgeblower is 12v from starter motor through to relay fed by 12v from starter moter (don't understand this duplex wiring). (Next Duh moment)
It seems like there is not enough voltage at low revs on starter, could this be because alternator is robbing voltage? Also I could put voltmeter on engine but have unnatural reluctance to get close to engine with fan belts spinning to get to test points strategically place in bowels of engine bay......
So how do I troubleshoot this beast?
Please bear in mind that engine room , fuses and connections are tucked in back of small cupboard where only double jointed pixies need apply! Can anyone help me understand for instance, why is there a relay and why not wired direct to ignition key and why I should not wire up to a relay placed behind ignition key.?
I will be honest I am not really an electrician, so I am not sure if I have understood this, my arms are ripped to shreds having been doing gynaecology through the keyhole for hours on end. No laparascope and therefore still not fixed it yet if anyone can help me understand and repair this pain in the RCE I will post you a decent bottle of vin rouge
anticipating in optimism
Answers on a post card please
Scenario
