Nigel52
Couldn’t understand why it seemed my batteries were flat on my boat when left on for the fridge with charger on. Checking the charger was working and 40amp fuses by the batteries ok, Then checked batteries were ok I was advised to remove the change over switch panel to find the back part had come away from the front panel which meant no connection of either battery. Speaking to my QS dealer it seems at least six others have had the same issue. As the boat is only 18 months old it will be a warranty issue. As this may take time for Quicksilver to action and repair and I don’t want to lose precious use I have put all the battery connections ie two batteries onto one terminal. It does mean I can’t isolate the batteries and any problems will bring both batteries down but least can still use the boat. Anybody else had this problem?
