sailaboutvic
We have a quick electric windless , It always been on the back of my mind if the motor packed up we will have a bit of a problem lifting the anchor , ok not impossible , but with a bad back ( three disks out over time ) lifting 20 kg anchor and X amount of 10 mm chain in any thing but light winds could be a bit painful , this year it came to pass , the motor packed up. In case the problem happens again or a failed power supply , I like to try and some how converted it the Manuel as well as power , has any one managed to do this , ?
When the motor was removed to be repaired I found that is was very early to turn the gear box with my finger , the motor will turned freely with no power going thought it , quick says they don't do a conversion kits .
so other then replaces it with a different windless , any ideas .
www.bluewatersailorcroatia.webs.com
