pcatterall
The one holding my prop shaft to the connector to be precise!!
I guess the answer is no but worth a try. I have tried to locate locally but without success (Sardinia)
It measures 8mm x 53 though I would have expected an imperial size on my old boat.
I was hoping to complete my PSS seal fitting before coming home for the winter. Fitted the seal without major problem but will have to undo it all to slide the connector back on and fit the pin. With the old lip seal I could have just slide the shaft through the seal of course...... The best laid plans!! Before any asks the roll pin has to be fitted with the shaft slide back as it is under a beam!
Anyway the quick question again.......is it safe to reuse a roll pin??
Thanks all
Thanks all
