Bajansailor
We are trying to get the shaft coupling off the shaft on a Jeanneau SO 40 which is fitted with a Yanmar 4JH4E 54 hp engine and are a bit stumped.
I have been told that the shaft is a taper fit on to the coupling - but the end of the shaft is threaded, which suggests that the coupling might be screwed on to the shaft (?).
Copied below is a photo of the poor coupling.
We did try putting a socket spacer in between the end of the shaft and the forward coupling, and tightening up the bolts, but that had no effect. Hence why I am wondering if perhaps the coupling is screwed on?
If this is the case, do you literally just apply enough leverage (perhaps with the propeller?) anti-clockwise to un-screw it?
The reason for getting the shaft coupling off is because we want to replace the (rather knackered looking) shaft seal (which is quite probably 14 years old now, with 4,000+ hours of usage on it) with a new Volvo seal for a 30 mm diameter shaft.
Changing tack, a couple of days ago the alarm buzzer on the instrument panel decided to set itself off, while the engine was not running.
Is it likely that this is just a tempermental buzzer, or is the problem more likely to be at one of the sensors on the engine?
