Question on boat electrics 12V
Sneds
26 Feb 2007
Bristol
Is it acceptable to wire new circuits, one for chart plotter, one for horn and one for the inverter, direct to the battery terminals with a suitable in line fuse?
I am sure it would be better coming off the 12V panel but there are no spare ways.
Any advice gratefully recieved. /forums/images/graemlins/smile.gif
PS I will probably end up pay someone to do this, if I can find someone!
Cheers
It sounds as if you might be better off with a subsidiary extra panel with modern RCBs and switches/lights, so that you have better control and electrical safety management of the accessories. Are you planning for, or can you think of any other bits you might add in the future - it would be annoying to put in a small panel when a larger one would save money in the long run.
Electrical kit patched on to battery terminals is a bit sloppy (IMHO /forums/images/graemlins/grin.gif) and does not inspire confidence when, as a third party, you look at such a birds' nest.
If you do it properly you won't regret it.
If you don't, you might have to !
Sort of what I was thinking, at the moment I have one circuit straight to the battery and any more would start to look messy!
Also, don't want a fire on board!
Been looking at various options and I think I'll put in an extra 12V dist panel fitted with circuit breakers.
Gotta be a better job!
Cheers
Speak to Anthony at Mwack marine in Bridgwater, think I gave you his number some time ago. He knows what he's doing and will sort you out. He also posts here on ybw.
