Richard10002
What started as replacing a wire from the stern gland to the anode has become a bigger job!
The stern gland housing seems to be brass, and it is one of those where you tighten 2 bolts which force a kind of tube, (gland follower), onto the packing... just like fig. 5 here:
http://www.diybob.com/diyPackingGland.htm
QUESTION - The whole thing is covered in a green type of corrosion, which I guess I could brush of with a Dremel and a brass wire brush??? Also is there something I could soak the nuts and bolts in to free them up, or id brushing and greasing the way to go?
QUESTION - If I remove the gland follower, will water come in.... if I remove the packing to replace it, will water come in. i.e. does repacking the stern gland need to be done whilst out of the water?
QUESTION - How can I tell what type and size of packing I need?
many Thanks
Richard
many Thanks
Richard
