Pete735
I've added an additional vertical floor support from the bilge up by using woven mat and epoxy resin to give the joint strength - fibreglas hull. This has been done after using 40grit disc on an angle grinder and acetone to clean area prior to applying epoxy and woven mat. 2 layers of mat applied along its length.
Any reason why I should not add some bulk to this by using chopped strand mat and fibreglass resin instead of epoxy. Reason is I've got loads of csm and fibreglass resin left from a previous job. I was thinking that I'd let epoxy harden off for 2 -3 days then grind surface back, clean with acetone and then use fibreglass. Doing this will the fibreglass resin take to the epoxy ok and give me sufficient strength?
