ffiill
Would it not just be easier to fly the French or Belgium tricolour and give the boat a temporary suitably French(or Belgium)name-then its highly unlikely that anyone will bother you?
Thanks for that but we have moved on, we are discussing a post red diesel future. The law doesn't say propulsion fuel must be charged at same rate as road fuel, red fuel duty is anyway different, higher than road fuel, only that differing rate can't be applied to the same fuel. A FAME free "white" is not the same as road fuel, so could be differently rated.No. There are two laws affecting this issue. First one says that fuel for leisure boating must be charged at the same rate of duty as fuel for cars and lorries etc. Second law says that duty free fuel for use where it is allowed ( tractors, fishing boats, heating etc) must be died a colour - almost everyone choses red but I believe the Micks chose green.
In any case our diesel isnt rebated. We pay the full duty on the but we use for propulsion. The other 40% is a standard allowance for heating. And thats why we are messing up the system, using diesel with dye in it but having paid full duty on it.
If you want a more detailed and accurate description , have a look at this
The Belgian Customs are more vigilant against Belgian flagged boats than UK flagged boats, so that would not work.Would it not just be easier to fly the French or Belgium tricolour and give the boat a temporary suitably French(or Belgium)name-then its highly unlikely that anyone will bother you?
Is it not possible to satisfy the EU and HMRC by adding a small second tank say 10L with a diverter valve. Use this when you see the customs boat heading for you, I am sure it may confuse them enough to give you the benefit of doubt. Return fuel could go into main tank?
Could be an added bonus if your main tank gets contaminated?
Can you be done if you are sailing and not using the fuel?
Yes just realised that you cant even carry it! doh..................
To reduce the staining caused by the red dye to the acceptable taint is it better to ......?
