Matt341
Hi All,
I currently have a Purflux primary fuel filter fitted adjacent to the diesel tank under the aft bed (awkward and restricted access), as part of the rountine maintenance I want to clean/replace/check this before the Winter.
I've had a good look at the unit and it seems to be the original fitted by Jeanneau. There is no glass bowl fitted but there is a small plastic screw fitted offset on the bottom of the casing which I opened into a container to check for any water (all seemed fine). I now want to replace with a new filter cartridge ready for next season but it looks as if it is designed to be cleaned rather than replaced.
The casing has a reference of "PP98DN" on it and what I can make out on the instructions printed to the casing is that the inner paper filter has a reference of "CN135", neither of which seem to bring up any products on the Purflux website. There is also another inner filter which the instructions show as being cleaned with fue rather than replaced. I have spoken to Purflux about this and they weren't able to provide any info/products based on the above references or description.
It looks as if the unit is held together with a bolt through the centre, although the head on the bottom is completely round (designed to be and not rounded through use). So at present I don't even know how to go about removing the filter casing from the fitting?
I will need to replace the inner paper filter but what should be used?
I don't like the fact that there is no way of visibly checking for water in the fuel so am now contemplating scrapping the unit and fitting a complete new assembly. However, it is mounted in a locker behind the engine with no bulkhead to separate so I don't know if the heat from this could cause damage to a filter with a plastic bowl? I'm also being cautious about any fuel leaks, the current Purflux unit is dry with no signs of drips etc.
Grateful for any advice/suggestions before I attempt to remove it next weekend with a multitude of tools ready!!?
Matt.
Matt.
