Ric
I've just installed a used PUR Katadyn 40e watermaker and am in the process of investigating and testing its various idiosyncrasies. Overall I am very happy with the performance which I have been testing methodically (and still gathering data). But I am also surprised by some of my observations.
At anchor, in water of about 22-23C, it produces 4.4-4.8 litres/hour with a current draw of 3-4 Amps which is broadly in line with the manufacturers claims. The output is of good quality generally and tastes ok.
However, underway in the same waters at around 4-7 knots, the output drops to about 3-4 litres per hour - this is with forward-facing dedicated 1/2" through-hull fitting as per manufacturer recommendations. Why does performance drop off underway? I would have thought the opposite would be the case.
I have a TDS meter which I regularly test the output. Sometimes this is as low as 160ppm (less than bottled water) but at other times (with only a few hours of shutdown) the ppm will go back up to about 440ppm (about same as tap water). So what is causing this fluctuation?
I left the system unattended for 48 hours (manufacturers recommendations is no more than 72 hours without pickling - so well within). I restarted with a 2l freshwater flush (i.e. carbon-filtered water through the pickling inlet). I was anticipating that there might be a bit of bad "rotten egg" anaerobic bacteria taste- - but on the contrary the output water was salty. How would salt get through the membrane? The taste and ppm did get back to normal after about 20 mins- but I don't understand how salt could have got through the membrane.
It would be interesting to hear about any other observations about the behaviour of these units.
