pessimist
.Managed to run the water tank dry yesterday, in the middle of my shower of course
Have now refilled the tank but can get only intermittent spurts and a lot of air from the taps. If all the taps are closed the pump keeps running until switched off but the system appears to be pressurised and will stay that way for an hour or two. I'm guessing that there is an airlock somewhere between the tank and the pump, any better ideas? Current plan is to break into the feed from the tank and pump water through. Should mention that the pump is hiding in some secret compartment somewhere known only to the builders, locating it would appear to require a major disassembly exercise.
Any suggestions gratefully accepted.
