strakeryrius
Regular forumites will know that I recently had the bad luck to run into a large and hard submerged object. One major rebuild of the starboard engine and both legs was completed about a month ago. The absolutely %$*&^ weather in July has prevented me using her much, but today we managed to get out.
The boat is pulling pretty hard to port., So much so that I had to steer about a point to starboard to stay in a straight line - it did this on all points of sailing so wasn't just the wind. It's doing it at virtually all speeds from as low as 5 knots, and at planing speeds the requirement to steer starboard is causing the boat to heel alarmingly to starboard, so that it was too hairy to do more than 17 - 20 knots.
What's odd is that the port trim tab seems to be stuck down, while the starboard is stuck up - which ought to make the boat steer to starboard. Its certainly not helping at all with the alarming heel to starboard.
Two other oddities that may be symptoms - the bilge is contaminated with some sort of oil, and its not from the engines as they haven't lost a drop. Also when I put her into astern to back into my berth I noticed that the leg trim indicator jumped from -4 to 0 and then back again when I came out into neutral.
Now putting all of this together I'm starting to see a pattern, but just in case I'm barking up the wrong tree can anyone else suggest what they think might be wrong?
