Ribtecer
Looking for advice please, I'm getting ready to lift out an inboard engine for a little maintenance, water pump, belts, oil filters etc. etc., and a clean up and paint.
Engine is a Cummings 2ltr 150hp QSD with a Mercruiser Alpha One leg,
I have done loads of work on outboards big and small but never an inboard. I have however had Landrover Tdi engines out and back in with no problems but there is a lot going on with this Cummings and space and accessibility is very tight.
I am hoping all the cables that seem to attach low down will lift up with the engine and can be disconnected as it rises and the connectors become visible and workable.
My biggest concern at this point is the hydraulic steering ram/mechanism inside the engine bay which is connected to the leg and piped to a pump on the engine. I'm thinking pull that out as well and keep it all connected, but again space is very tight.
Any advice would be very welcome with regards to what I should do and what I should expect to go wrong.
Many thanks
Many thanks
