Plevier
Like others on here I've used PU40 and been quite happy with it, and the data sheet for it http://www.everbuild.co.uk/image/data/Tech Sealants/Puraflex 40 r.6.pdf says it's OK for marine applications and withstands salt water.
However I've noticed the manufacturers of it also have a specific range of marine products called mSEAL , see http://www.everbuild.co.uk/sealants/marine. mSEAL 295 appears to be the general purpose one, http://www.everbuild.co.uk/sealants/marine/mseal295 From the spec sheet it is slightly harder and less extensible but same tensile strength as PU40.
So if PU40 cuts the mustard, why have a separate range? Anyone got the mSEAL stuff?
Wondering now if I should be using PU40 for doing the new skin fittings as I intended (although I guess that isn't really the most demanding job, as if you do it right only a very thin edge will be in contact with the seawater!)
Edit - just noticed Force 4 sell it a £9.95, approx twice the price of PU40 from Toolstation.
