Orla
Completed sanding the deck and now completed removing all exposed screws and thin plugs.
The screw that have been removed were countersink type, I am replacing them with A4 pan heads.
Should I coat the screws in anything or inject the existing screw hole with anything prior to fitting the new screws?
I have manage to keep most of the holes at 10mm some may have to go to 12mm, all the original plugs have been epoxied in place, I've noticed that this can leave an epoxy ring around the wooden plug in some cases. Some people recommend using varnish (sounds good for interior plugs) or nothing at all. I was thinking about using Weldwood Glue (came across it in the local swindlery yesterday) the local professional at this kind of work suggest I stick to epoxy, what do you think?
