rogerthebodger
Any one know the size of the grub screw that clamps the stainless rotor on to the prop shaft.
Mine is a 40 mm shaft and need to adjust the rotor as the compression is less than then 25mm it should be.
I know I can get a set of grub screws from PSS but I can get them local from a local bolt supplier.
I have looked on the PSS web site but not found the info.
