Trident
I have a Snowgoose 35 which had had the in-keel tanks decommissioned and replaced with bag tanks. As these chaffed, leaked and generally were a PITA as well as holding only half what the keel tanks did I have re-comissioned the in keel tanks. I cleaned, repainted with potable epoxy, built new inlet and outlet and breathers, sealed the tops and was ready to fill when...
I found right at the very back of the tank, at the very top (part way back under the rear bunk for those familiar with the Snowgoose) a tiny copper "spout" glassed in to the tank top. It has a piece of microbore hose attached which has been cut off in the dim and distant past (the same hose as is used for a Webasto or Eber fuel supply so really small)
I have no idea what this would be for - because the hose is just cut after a few inches and left I don't know where it would have routed or what the purpose might be - the tank has a large bore breather already, AFAIK there were no gauges fitted to these boats (and I've never seen a manometer type gauge that would need a hose feed on a boat)
So can anybody shed light on what this might be and is there any reason I can't just seal it off?
