Props are old fashioned - jets win?
Gludy
19 Aug 2001
Brecon, Wales
www.sailingvideos4us.com
As the thread on this subject has almost dissappeared from the bottom of the page ( I wish forum admin would arrange thread ranking by latest post), I have started a new thread on this subject - the last thread ended with a number of points being raised about Jets that I have investigated and waish to answer in full:-
Drag caused through Jet intakes -
Intake velocity to a jet is almost exactly the same as the water moving along the hull so it is not right to say it travels very fast through a grill. There are of course losses associated with water friction and direction changing through a water jet but appendage drag is something else - it is a combination of friction and simple frontal area of appendages which resist movement through the water.
There are different types of surface drives some with rudders etc and so their drag will vary as well. A general rule of thumb is that water jets are most suited for boats with top speeds up to 45-50 knots. Above this speed the surface drive does show an improvement in efficiency over conventional jets. For jets to match theoretical efficiencies in this high range, special designs ie multi stage units or special intake configuration etc are necessary. We should also remember that to optimise any propulsor for high speed invariably causes some downside at other operating conditions.
In high speed craft, the engine position is a function of where they need to be to achieve optimum boat trim. It is in fact the surface drive that has the engines further aft because this is generally what is wanted for high speeds of course.
To compare true performance, we should first of all establish what tthe cutomer is looking for. Sheer top speeds ie in the 50 knots plus range, and the surface drives are very popular. This is a specialised section of the market and for the majority of owners, the huge list of water jet advantages far outweighs the ability to gain an extra one or two or even 5 knots!!
Yes, stopping in a hurry can result in getting seriously wet, but if the choice was get wet or hit an obstacle at 35 knots, I know what I would prefer ! Just because something CAN be done, does not mean that you have to do it every time!
The impeller clearance is not critical with the Hamilton design that I am researching. Units which use tapered impellers and bowls do indeed show drastic loss in performance and require frequent refurbishment if you operate at high power in very shallow and stoney conditions. Still what would happen to any sort of propeller if you abused it like that?
Corrosion is something which has to be considered on all craft and provided we stick to the manufacturers recommendations, there really should not be big problems.
So, from all the points that have been raised to date, for most pleasure boat applications it seems to me that not one point has been raised that favours props as the best means of propulsion. Props are old fashioned - I would like someone to really take me to pieces on this, as I can only learn more by them doing so.
So go on - let us know why props are better!
Paul
andyball
1 Jun 2001
Re:Because they work ! NH.
and they're cheap (ish),and loads of places can fix 'em.
maybe jets are being held back by the stonecutters?, like the electric car & the metric system in the US
tcm
11 Jan 2002
Caribbean at the moment
Re:disadvantages :jets lose. D\'Oh!
Disadvantages
1 Fuel consumption. For a given engine, boat and speed, fuel consumption will be worse. Quite a big issue this, I wd imagine, knocks it stone dead for many, no?
2. From above, for same boat, range is reduced. Or accommodation reduced with larger tanks. So top speed down further cos also carrying more weight as well as not best solution.
3. Unfamilarity of engineering. Yes, sure they can get to know these, but wd charge a premium, and/or you'd have to find the right bod. With the scarcity of skilled labour this is a problem.
4. Low speed manoevrability. I have a 115 hp jet rib and it is a bit weird at low speed, not at all easy to manoevre. No paddle wheel effect for alongsde berthing, and need to master "gunning" the engine to get it moving a small amoiunt, instead of being able to use lower engine revs on props.
5. Unfamiliar handling characteristics at higher speeds. Yes! Instead of the boat carving along its route, with the rudders forcing graceful changes in direction, a jet boat can be doing 30 knots in another direction, turn the wheel and it gets shoved sideways up onto its own wake. Then coliholic gets thrown out into the sea.
kgi
29 Apr 2002
andros bahamas
why do all the major armed forces in the world still use propellers then if they are so outdated? you are obviously talking yourself into this, so relly carrying on this thread is awaste of time, ive used jets, props are simpler, can be purchased virtually anywhere, if you want to be a technophile you go ahead
kgi
29 Apr 2002
andros bahamas
way to go TCM agree with you, not a hundred per cent but near enough, so you have experienced the handling vagaries of jets as well eh, they can be fun but i will stick with props cheers keith
jfm
Jersey/Antibes
Re: Gludy you are wrong on drag
Gludy, you have massively played down the drag/friction in jets. See my post below in your other thread.
You are quite wrong when you say "Intake velocity to a jet is almost exactly the same as the water moving along the hull so it is not right to say it travels very fast through a grill." Make no mistake, the velocity at which water passes thru a jet tube is massively, I mean massively, faster than the boat speed. Jets work on Newton's action/reaction stuff. They work because water is squirted out the back very fast indeed.
Then you say "There are of course losses associated with water friction and direction changing through a water jet but appendage drag is something else - it is a combination of friction and simple frontal area of appendages which resist movement through the water". You are getting hung up on semantics. Appendage drag is more commonly applied to prop installations but drag is drag, whatever type. Just like a prop installation, the impeller, driveshaft, impeller hub are all in the water flow in a jet unit (except the weater flow is faster, so drag higher). But with a jet the intake grill, tube and nozzle are in there too, whereas these items dont exist in a prop set up.
So jets lose on efficiancy, no debate. This expalins TCM's comments below. If you want efficiency, get surface drives, and these are not just beneficial at 50kts they show big advantages at 30kts too.
Gludy
19 Aug 2001
Brecon, Wales
kgi - "so relly carrying on this thread is awaste of time".
This thread has now livened up a lot, which is exactly what I wanted. I am new to boating, I have opened a debate that interests me a lot and in doing the research to answer all these new points, which I intend to answer in full, I am learning.
It does not matter if I am right or wrong in what I say - if I am right, then I have learned a lot along the way. If I am wrong, I have learnt even more. What matters is the truth about any subject, not who is right or who is wrong. So whilst working on a detailed response to all these great points that have been brought up, I could not resist posting this response to strongly disagree with you about the carrying on of this thread being a waste of time.
As a beginner to this game, I want to ask questions and learn - if my views at any particular time offend any of the more experienced than me on the forum (which just about includes everyone), then that is their ego problem, not mine.
I would say that the Ministry of Defence has now ordered jet boats and will be using them, so as a fact, it is not true that the armed forces do not use jets. However, either way, the particular requirements of the armed forces will probably be very different to the marine leisure boat market. So by itself the fact that they do use jets, is only a small matter in my current support for jets. However, as your argument is not true, you cannot use it.
I promise a detailed response to every point raised - I am only after the factual truth and wish to seperate out fact from myth.
It would be a great idea for one of the mags to do a serious in-depth article on the subject - wouldn't it?
Paul
adarcy
31 Aug 2001
Gludy
I am a bit behind and posted in your original thread.
Agree w jfm about added drag but don't know if it is more or less than doing without underwater gear. Obviously, there must be a much greater speed of water throught the intake else the jet is driving much!
Also I reckon that fouling and barnacles etc is probably a greater problem with the finer tolerances of a jet tunnel and the same loss of efficiency as in normal props. As I posted before, unless a jet prop isn't in the water, how is it going to avoid fouling.
Anthony
kgi
29 Apr 2002
andros bahamas
well its nice to see we can wind each other up!!! as for the british military using jet boats, yesthey do but have you seen how small they are, i had a go on the prototypes when they were introduced in the RN, if you want to see how manouverable they can be see if you can find some film of the riverine pt boats in Vietnam, someone else to ask might be the folks at adrian thompsons yard find it under VSV on the net now theres an interesting boat!!! sorry to wind you up like i did, but it works both ways keith
jfm
Jersey/Antibes
Mr Angry of Surbiton complains about armed forces
kgi, I agree some of your views but always get wound up when people say something must be right/wrong because the armed forces do/don't do it. Since when did they have a monopoly on engineering knowledge? As they pay massively lower wages than a clever engineer can get in the private sector, I'd guess they tend to get a bit less grey-matter per capita. And that's before you take into account the massive political interference in their equipment sourcing. So, as a general rule, I'd buy what they dont buy........
andyball
1 Jun 2001
Re: Mr Angry of Surbiton complains about armed forces
the army use can-am /armstrong/harleyD(no, not quite like that) m/cycles, but they're still nbg. Do the sas use 'em ? no way,they need something reliable.
Bergman
27 Nov 2002
Re: Only Solution,
Take 2 identical boats 1 with props, one with squirty things.
Tie blunt end to blunt end with thick rope.
Give each boat big welly
See which way they go
Think thats why we have props instead of paddle wheels.
PS
Can I come and watch?
jfm
Jersey/Antibes
Heisenberg Uncertainty Princip nearly gets Bergman
This isn't really a great test, because boats need to be moving (planing speed), but agree general idea :)
stamfordian
28 Dec 2001
LINCOLINSHIRE
Only experience of jet boat was on a cold winters day on local sailing clubs safety boat,damm thing kept getting fouled up with weed,and guess who had to do some underwater work with spanner...in end we had to fit new impeller bit difficult underwater but managed,the wear on the jet tube if thats what you call it was herendous...so no thanks props win for me tolerances too fine,IMHO.Not an expert but this experieance has put me off this sort of drive.
If things don,t change everything stays the same.
jfm
Jersey/Antibes
quantum physics (marine division)
It's really a quantum physics theory that says you cannot know all the circumstances of a subatomic particle, but by extension the term is used (as I was using it) to refer to a case where the very act of trying to measure something causes a change in the thing you're measuring, thereby corrupting the result. So if you try to measure effectiveness of high speed boat's propulsion and your test actually involves holding the boat near stationary, your test has itself screwed up its own result, see? Kind of, anyway. Apols for all this bolx, to any casual readers
longjohnsilver
30 May 2001
Calling Haydn
Thanks John, didn't understand a word, if it wasn't for the correct spelling would have suspected Haydn of taking over the jfm pseudonym! ;-)
