I would like some advice on improving the set up of my Inboard/Outboard arrangement.
I have a Ford 416 XLD 1600cc diesel, with an Enfield (model?) outdrive, all squashed into a Fantasy 20(possibly?- Very little information was available when I bought the boat)
Now its a pussy cat on the canals and will trawl along at 3-4 knots at little more than tickover creating little more than a ripple. However, I spend most of my time on the Severn and the RPM required seems disproportionate to the progress made. The engine does not sound like its actually doing much work.
Is it under propped? 60 ish HP engine and 20' boat would seem to be a fairly swift combination on paper. When you open it up it doesn't produce a great deal of wake, so the hull seems appropriately shaped for moderate speed.
Its currently running a 12.5" x 13 pitch well battered(BCN canals for you!) ali prop. I guess the top speed is 15 knots - speedo is not working - another winter time job!
I would really appreciate any guidance not on improving top speed, but reducing RPM at comfortable cruising speeds mainly to reduce the noise. As I said the prop is decidely 2nd hand after 10 days on the canals this year so its due to for change. I'm not sure I could physically fit anything larger diameter onto the Enfield.
I would also like any information about the Fantasy 20 (where and when was it built) and the Enfield outdrives (maintenance schedules/requirements, is the propellor compatible with other makes, whats the largest prop that may be used etc) that anyone may have.
I know its a big ask, but thanks in advance for ANY info that you may have.
Jason.
Jason.
