Propellor - paint or not?
Greenwichman
14 Nov 2004
Tollesbury
Have just spent ages cleaning layers of old antiifoul and primer off the prop of my Beany 285. Big ships leave their propellors unpainted, why don't we /forums/images/graemlins/confused.gif? Any advice?
Have you tried white teflon grease? I've put it on this season and will let you know how it goes. On the few times I have used AF on the propeller, the barnacles and weeds grew as readily as ever. Last year I used normal underwater grease, and it worked quite well.
I polish the prop each year and get just as much (little?) growth as I used to get when I antifouled it. There used to be lots of advocates for anhydrous lanolin, which is painted on then smoothed by heating with a hot air gun, but I've never ben convinced.
I use the old ZEBO fire grate polish on mine re-applied every year, and worked well in, a tip I got from my old engineering instructor years ago. Believe me nothing ever grows on that prop.
I did the polish/lanolin/hot air gun routine last year, and it worked OK. It was probably a little better than the best year I had using antifoul, but pretty comparable. But I have had some awful results using hard antifoul over the years, though, so I'm going to stick with the lanolin. I got mine from Classic Marine.
