All_at_Sea
My bronze prop is covered in a limescale type stuff, very hard to shift. Is there a chemical that might do it without damaging the metal? I have searched the forum but no luck.
Brick cleaner from the builders merchant.
There is a dilute form of hydrochloric acid that can be used with no ill effects,,,,certainly not over a lot of years I have used it!
In Spain its known as Agua Fuerte but I understand you can get it in the UK as 'brick cleaner'
Used it on 3 boats this year, no problem, good to have a hose ready to thoroughly dilute and rinse away arisings.
Hope this helps!
Muriatic Acid is a strong, corrosive, inorganic acid (HCl), manufactured by absorbing hydrogen chloride in water. It is one of the most corrosive of acids, and is particularly destructive to cellulose, breaking the cellulose chain into even smaller units, resulting ultimately in its complete hydrolysis. It is the same chemical as Hydrochloric Acid.
Uses include cleaning brick, etching concrete, cleaning metal and for swimming pool maintenance. Will attack varnish, fabrics, metals, plastics, most paints and many other materials. Can be diluted with water.
Not all brick cleaners are hydrochloric acid based.
Check the label and the safety data sheet.
Bronze props are likely to be manganese bronze which is not a true tin bronze. It is a copper zinc alloy, ie really a brass ,containing only a small percentage of tin.
Take care only to remove the lime scale type deposit and not to de-zincify the prop.
What about plain white vinegar? Put the prop in a vinegar bath for fifteen minutes, wipe clean and rinse. Has always worked well for me, never seen any ill effects on the prop.
