SnaxMuppet
I have read all the posts concerning propellers and propeller sizing seems to have been "posted" to death but there has been very little discussion about the effect of propeller size on fuel consumption.
I have both the standard 17" and a 21" pitch prop for my 140hp 4-stroke outboard.
My question is this: Would I get better fuel consumption from the 21" pitch prop or the 17" pitch?
I understand the issues surrounding WOT rpm. Both props would be fine if you use the WOT rpm test... the 17" puts the WOT on the max allowed and the 21" puts it on the minimum allowed (convenient!).
Clearly, the 17" would give better acceleration and better times to planing and the 21" would give lower rpm when cruising at a particular speed (and hence quieter) but which would give me better fuel consumption?
The issues for me seem to be that with the 17" I will need a higher rpm but the engine will be more lightly loaded.
This is a tricky one for me and I would appreciate your thoughts.
