Propellers ally/stainless
FTBSQ
28 Apr 2003
Port Solent
Can anyone help.
I have a Hunton 36 with x2 volvo KAD44's and I'm currently running aluminium props, but they seems to dissappear!
I am thinking of buying Stainless steel props 'C7' but volvo are soooooo expensive, surprise surprise, steel developments can do Solas props which they say are a better all round prop.
I have even thought about buying abroad
Such a minefield can anyone shed light
Geoffs
15 Jun 2001
Wantage,Oxfordshire
I@ve been using a Solas prop from Steel Developments for 3 years now, on a Mercruiser Alpha One. Performs very well, whether it is better than Volvo, I can't say, but certainly very good.
Get a bit of surface corrosion, just tarnishing of polish really. Certainly don't get eaten away, but aondes dissappear faster with S/S.
<hr width=100% size=1>Old Chinese proverb 'Man who sail boat into rice field, soon get into paddy'
FTBSQ
28 Apr 2003
Port Solent
Thanks Geoff it does help to pick someone elses brains, this is a really good forum.
I do think us motorboaties are more friendly than yachties! oops did I say that out load!
Col
14 Oct 2001
Berks
In what way do they dissappear? Corrosion? Fall off (I'm an expert on props falling off) Either way can give you more in depth advise.
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/colspics> Cols Picture Album</A>
FTBSQ
28 Apr 2003
Port Solent
well the falling off part isn't true, at least not up until now.
I bought the boat sept 2003 and when she came out of the water one set of props where too pitted to be repaired so I bought a new aluminium set. The thing is I do use shore power all the time and think that this going to cause the metal work to corrode faster. I thought I might buy stainless props so I didn't have to spend anymore time thinking about it, also I have heard that becasue the stainless blades are thinner that ally they will give much better performance, and I do like going at my top 48 knot speed!
Sorry didn't want to overload you with info
duncan
Home mid Kent - Boat @ Poole
the bad news is that stainless props will probably give you an even greater top end!
it's not because they are thin - they don't flex and deform as much.
however you must keep your drive anodes 'up to date' or you will have nice shinny props and no legs
Col
14 Oct 2001
Berks
100% agreement. Just add to that........Stainless props DO rust. I would add extra bar annodes on the hull, and get the electrics checked for stray current electrolisis(sp?). Good luck
Ps. Do you want to buy a set of 3 C5 duoprops, the missing rear (smaller) props are available in Weymouth harbour / Newtown creek / Southampton water. You choose which place is nearer/forums/images/icons/laugh.gif
Talbot
23 Aug 2003
Brighton, UK
When you have been on the forum for longer you will discover that we raggies have been known to speak to mobos (without being threatened with banishment)
We all have similar problems and the collective knowledge on these forums is staggering - or could that be the amount of alcohol we all drink /forums/images/icons/smile.gif
Dave_Snelson
16 Oct 2001
Porthmadog / Port Leucate
www.makeyourowngarments.com
Agree with all comments below, and I would add that steel dev know a thing or two about props. Give them all your boats info and let them work out pitch, blades, overall suitability. 48kts eh!! Bet that puts a smile on yer face! (and I just love Huntons - though mine's a Windy)
<hr width=100% size=1>Madoc Yacht Club
<A target="_blank" HREF=http://www.madocyachtclub.co.uk>http://www.madocyachtclub.co.uk</A>
MapisM
11 Mar 2002
You might be interested in some other reasons behind the reliability of props.
I posted <A target="_blank" HREF=http://www.ybw.com/cgi-bin/forums/showthreaded.pl?Cat=&Board=mby&Number=219172&Search=true&Forum=All_Forums&Words=Radice&Match=Or&Searchpage=0&Limit=25&Old=allposts&Main=219148> these </A> comments on that, some time ago.
Luckily, since some years now, I am not dealing with duoprops anymore.
Maybe the situation changed in the meantime...
...or maybe not?
