Tim Lee
I am replacing a leaking volvo stern seal. I am planning to do this next weekend dried out between tides. I was going to pop down to the boat this weekend to make sure I can loosen off the prop shaft from the coupling. This seems to be the most likely part of the exercise to cause excessive use of expletives!
However, it has just occurred to me that I have a rope stripper. It is this type -
http://www.ropestripper.com/strippers.php
- the one advertised by the bare chested female in the comics!
I bought the boat with this already fitted and what I can't quite work out now (and can't visually check with the boat still in the water) is whether the two faces of the stripper mechanism will just come apart when I drop the prop shaft back or whether they are held together somehow.
Obviously I want to avoid forcing the prop shaft off and damaging the rope cutter in the process.
Any help greatly appreciated.
