westernman
I have a Jprop and the boat yard have messed around with it the last time the boat was out of the water.
Now, I am getting a speed of just 5.4 knots forwards at WOT and hitting 3800 RPM - the max RPM for my engine. According to my calculations (assuming about 35 tons all up weight, and 45ft waterline length), I am using just 12 HP from the engine to attain this speed. The engine is 85HP.
OK so far so good, so the pitch is way off, and needs to be substantially increased. According to my calculations I should be getting 8.4 knots at WOT. So presumably the pitch should be increased in the ratio 8.4/5.4 right?
However, the bit I don't understand is that in reverse I get a maximum of 1800 rpm on the engine instead of 3800 rpm. If I increase the throttle beyond the position I initially get 1800 rpm, I start to get large amounts of black smoke for very little change in rpm - i.e. it looks like the engine is seriously overloaded.
Acceleration in reverse seems to be fairly good (for 35 tons). Acceleration forwards is very poor.
No idea what top speed in reverse is.
Is there anything I have got wrong?
