chrisD
my replacement engine rotates in the opposite direction from the old one. Hence the prop needs changing from LH to RH. Is the thread on the end of the shaft only suitable for LH? Comments welcome.
do you change it every time you go into reverse ?my replacement engine rotates in the opposite direction from the old one. Hence the prop needs changing from LH to RH. Is the thread on the end of the shaft only suitable for LH? Comments welcome.
Pedantically speaking the taper and the key work together to stop the prop turning. ?No need to change - I replaced my engine (and therefore prop) a few years ago without changing the shaft and nothing has fallen off yet.
The prop is stopped from rotating on the shaft by a key and if the prop can't rotate there is doesn't matter which way the nut that secures it is tightened (plus that tends to be castellated too)
Same as a Volvo saildrive except the prop is on a splined shaft.I used to have an old Scottish 60' converted fishing boat, which was fitted with sterngear by Fleetwoods of Lossiemouth. Her 49" four blade propeller was held on in an interesting manner. The shaft was 3.5" diameter. A large cone nut with a relatively fine thread held the prop onto the taper, and then a bolt was screwed in through the tip of the cone nut, into a tapped hole in the end of the shaft. The large cone nut was a right hand thread, and the bolt, or set screw was left hand. It meant that there were no split pins or grub screws at all. It worked.
