dunmor
Does any body know where i can get these from. i have a chance of getting new props but they are for 1.5" shafts. mine are 1.25. many thanks in advance. have been on google but all the supplyers seem to be american.
I can make some sleeves for you, but how are you going to lock the prop to the shaft?
if you look on the american sites, they sell them with bigger keys to lock all three together.
They usually include a stepped key. The US sites offer also nylon prop reducers which are OK for smaller hp engines. You have 4.107s, I think, and they should be OK with nylon bushings. They're only about $25 each, so would be worth a try.
trouble wiyh nylon is the bonding of prop to shaft. yes you are correct with the 1407s. about 40hp each im told.
the nylon would insulate the prop to the shaft. the shafts are earthed to the engine to stop erosion. would my props erode??
No, they wouldn't. My bronze skin fittings aren't connected to anything, and they don't erode.
Fair enough, i just need someone who can supply them in england then.
would this not take a long time?
So the key would have to be 1/8" taller than standard. I assume this would be just a straight key rather than woodruff or such? Would you be able to measure the keyway accurately?
