Prop won’t go into gear
Bronco99
20 May 2020
My problem is that the hub on my stern drive is responding fully to the throttle but the prop, although responding direction wise as if in neutral, won’t go into gear.
Any thoughts appreciated.
The rubber hub inside the prop has failed.
They're a sacrificial part designed to save the gearbox If the prop hits something,but they do just fail on their own sometimes. The prop will need to be removed and a new hub needs to be fitted.
It shouldn't be too expensive.
Get a price from castle for repair
I suspect there is also a lack of props available now from Volvo
sillete may have mor options without Volvo added tax
