CJU
I have just fitted a 17x11 3 bladed prop and have found that between 1,000 and 2,500 rpm there is quite a loud whine, it seems OK outside of these revs. I think the noise is also there when the prop is wind milling under sail but is not so loud. I have yet to try it astern or while moored up.
The yacht was fitted with 16x11, which was undersize but whine freee. It is also fitted with an Ambassador rope cutter and the new prop has been modified to accommodate this.
Has anyone any suggestions as to the cause? People have suggested various reasons:
Prop out of balance-I would have thought this would result in more vibration.
Cavitation-not sure about this.
Water flow over the prop and nut-the fairing of the nut to prop boss is not good but I have no idea what effect poor flow would have.
The rope cutter-I have asked Ambassador about the problem and they have never come across it before. They think any faults with the cutter would result in clicking rather than whining.
Engine/saildrive-I contacted Barrus who hadn't come across this before but suggested it maybe due to cavitation.
Sillette props thought it maybe 'prop sing' and a possible cure would be to chamfer a 45deg angle on the aft facing, trailing edge, from the tip to 2/3rds down to the root. This seems a likely cause but I am reluctant to apply the cure, as it means repainting the prop before the tide comes in.
I wondered whether it will resolve itself in time but I am not sure what damage it maybe doing. Not to mention how uncomfortable it is under power.
