ben lomond
New Member
Can any one offer advice on how best to repair and fix in place the "stern tube" through which the prop shaft rotates. The hull is GRP and the vessel is 24 feet, driven by Yanmar GM10.
Ben Lomond
Ben Lomond
It certainly looks like it was glassed in at manufacture time. (1973) I`ve got photos showing both ends of the tube. It is a very thin walled tube and although angled through the boat , exits through a brass bush which presents a vertical face at the rear of the boat. Yesterday was my first ever post and I don`t know the PBO forum you refer to .How would I contact this . Photos will be supplied but need a visiting grand child to show me how. Thanks for replying.Depends on how it was fixed in the first place. Some are glassed into place, but most are physically fixed with flanges at either end bolted or screwed to the hull. You need to identify what has failed. photos would help and you would do better with this type of question on the PBO forum.
Looking at your photo 7 it is unclear whether that is the tube extending aft from the skeg or just the shaft. If it is the shaft then there is far too much overhang, but there is enough room to replace the tube with something much more substantial.
