Appledore
A couple of years ago I noticed slight corrosion on the prop shaft when I undid the stuffing box to check the packing. Previously I had used a hemp packing, with lots of grease on it, but obviously this deteriorated fast and allowed too many drips, which meant I had to tighten it after every trip. I also have a greaser on the prop shaft. Last year I repacked the gland with Reinforced Graphite Gland Packing (Ebay). Last week I checked the shaft again and noticed that the corrosion appeared to be worse. It is just where the packing would be on the shaft.
I read somewhere that trapped water could cause shaft corrosion, and this perhaps could have been the initial cause, but on reading Nigel Calder's book he says (on page 548) 'graphite impregnated packing material shall not be used because of the possibility of galvanic incompatibility with the shaft material', and I wonder if this is the cause of the further corrosion.
Calder also mentions Dripless Packing, which has 'a crumbly, clay-like consistency that can be rolled between your palms until it is an appropriately sized diameter to go in the stuffing box. It is sandwiched between outer and inner rings of conventional packing which keeps it form working its way out of the ends of the stuffing box'. He mentions that the original drip-free packing consisted of shredded Teflon (PTFE).
What I intend to do is clean up the corroded part but not 'flatten' it, and fill the shallow void with JB Weld or the like, then suitably sand back to a smooth finish the same diameter as the shaft. It isn't that deep, and is pock-marks rather than scoring. But what do the panel recommend for the new packing? I thought, like others, that graphite was OK, but it appears not to be the case. A new shaft will be fitted before long!
Thanks for your comments.
