Prop pitch
Jegs
7 Jul 2007
Firstly, I have bought Mr Gerr's book &, if I live long enough, I hope to make full use of it. The supplied prop is 22x14 & I wonder if altering the pitch to 15 would make any discernible difference. What do you think?
Thanks,
John G
Latestarter1
6 Feb 2008
Somerset
Thanks,
John G
Are you making engine rated speed plus droop with 22X14, clean bottom and half tanks?
Latestarter1
6 Feb 2008
Somerset
Yes & I think it might over-rev if pressed. Thank you for your time.
John G
John
You cannot over rev a diesel engine, high idle governor cuts in at rated speed and progressively reduces fueling (governor droop) on mechanical marine engines droop is around 10%.
Marine engines have less droop than say automotive engines 15% droop as it gives more stable steady state governing at part load.
Give your motor the beans with clean bum and see if it meets spec rpm on data sheet WITH calibrated tacho, you will do it no harm if you can make rated rpm. Compare with 'high idle' test.
